mjrippe said:As long as the PSUs are *properly filtered* and only supplying DC voltages there will be no sonic difference between the two. Really, DC is DC. So long as the supply can provide the correct voltage and current all will be well.
outoftune said:i have been seeing a lot more audio products using SMPS these days...just wonder if anyone has ever done an A/B comparison between a linear PSU and SMPS with the same circuit...and if there is any audible difference?
Brian Roth said:I know that SSL had a huge filtering box that was part of the SMPSU on their 9000 series consoles. I found one mention of that unit, apparently filled with a bunch of L and C components, and that filter box is 9 RU in size and weighs 200 KG.
It is... Near the end of my tenure managing a mixer engineering group one of the larger mid-sized mixer that was previously using an external power supply was able to build in a much smaller (and universal voltage) switching supply. Contrary to all the radiated noise fears from high edge rates, look at the magnetic circuit. Instead of 100 or 120 large current (magnetic flux) pulses per second, there were tens or hundreds of thousands of tiny magnetic pulses per second. So smaller magnetic flux per pulse, smaller magnetic field. Sorry I don't recall any details only that SMPS were already delivering on their promises well over a decade ago. The power supply was several cubic inches and easily nested inside. Back then it was that cheap, but the cost savings from eliminating the separate PS chassis, power cable, and hassle factor, was well worth it.soapfoot said:Brian Roth said:I know that SSL had a huge filtering box that was part of the SMPSU on their 9000 series consoles. I found one mention of that unit, apparently filled with a bunch of L and C components, and that filter box is 9 RU in size and weighs 200 KG.
Interesting-- particularly since one of the advantages of SMPS is usually said to be size and cost.
