guitarrock04
- Joined
- Feb 14, 2008
- Messages
- 60
I would like to build a sonic maximizer clone. A bass player friend requested it of me, and looking into it, it isn't much more than an integrated circuit and power supply. Of course, the IC is a proprietary piece. I've found a couple examples posted elsewhere on the net of someone who emulated the circuit with simple op amps and components. My depth of knowledge isn't great enough to tell whether these schematics I've found are worthwhile substitutes or not.
The BBE IC, NJM2153, datasheet can be found here:
http://www.datasheetcatalog.org/datasheet/newjapanradio/de04020.pdf
It gives a pretty good description of the circuit, but with no component values.
The substitute circuit I came across, intended for pedal use, is as follows:
Does anyone see any obvious hang ups? I would appreciate some expert opinions before I commit to building it. The main thing that's bothering me is the absence of a VCA that's stated in the IC block diagram. Maybe it isn't necessary, but I would like to get as close as possible to a discrete version of the original.
Any help is greatly appreciated.
