Woot
Hey All,
Just wondering if someone could please help a n00b [me] to troubleshoot a bad Sony c37a power supply.
So I was lucky enough to acquire a pair of Sony c37a's, which I was told were in completely working and original condition with only one of the tubes being replaced at some time.
When I received the mics, one of the power supplies would turn on (power lamp on) but was putting out a very very low, distorted signal (using the same mic that sounds great through the other supply).
The supplies are the solid state CP-3B variant.
I have read some other threads here on these mics and supplies but I am still a little stuck. I am also new to the concept of a floating heater voltage so many of the readings don't make much sense to me.
The first thing to note on the power transformers is that the B+ secondary has a used 240V tap (pin 7) and also an unused tap at 220v (pin 6). On the power supply that is not working it looks like the 240V winding is open (whereas I am reading 2k resistance across pins 5 and 7 on the good one).
As a remedy, someone has just shifted the diode down to the 220v pin 6. The rest of the circuit seems to be original and identical to the working power supply.
Needless to say, the voltage readings that I'm getting on the B+ for the broken supply are less than those from the working supply (but only slightly).
The reading across both supplies H+ is ~17.5 VDC (again this I don't understand because I thought the maximum heater voltage should be around 6.3V).
Is this going to be the cause of my problems? Or would you expect the mic to still work, just with a slightly lower output?
Any help or advice greatly appreciated!
Regards,
Matt
Regards,
Matt
