Sony C37P DC/DC Converter Problem.....
la-2a
Germany
Hello people, I'm in the process of bringing a Sony C37p back to life. I suspect the error (too little level) in the DC-DC converter. A question for the experts. Can anyone confirm the correctness of this circuit? Somehow I don't quite understand it. The conductor tracks don't quite correspond to the circuit diagram either. In addition, there are no names printed on 2 components that should actually be diodes. Unfortunately I can't measure anything even when it's removed. I marked it in the photo. I really appreciate your help and would be happy to be able to solve my problem.
    592.6 KB
  • Sony DC:DC.png
    Sony DC:DC.png
    135.1 KB
Hello, I cannot measure the polarization voltage with my voltmeter. To make sure that the DC/DC converter or the CL 112B module in which the FET is located is defective, I would like to connect a Chinese tube power supply that supplies 135 V to see whether the CL 112B is OK. . Please help me get the 140V to the right place without breaking anything. I have attached the circuit diagram. Thank you very much.
  • Sony_C37P.pdf
    64.4 KB
I do not recognize that topology.
The component in question may not be a diode, that does not appear to provide any functional purpose. Perhaps a resistor there could serve to RC smooth the output. Alternately if the supply is using a cap as a doubler the circuit connections do not look correct.
Sorry not much help.
Why would you want to apply 140V ANYWHERE inside that mic???
The microphone requires a polarization voltage of 140V. To get the 48V Phantom to 140V you need the DC-DC converter. The module that houses the FET and some resistors is called CL 112B and is potted. Both tend to be broken. To make sure the CL 112B module is OK, I thought about testing the mic with the external polarisation PSU instead of the DC DC converter. NOT ANYWHERE ;) . Since I'm not sure about the correct connection, Voltage + or - DC and don't want to damage the output transformer and module. I wanted some assistance.
That's a good question. I have the circuit diagram from the gyraf site. Somehow the circuit does not correspond 100% to the conductor tracks. @JohnRoberts which capacitor do you mean, the one betweed the 2 diodes. @Khron as I understand it, I leave the 48V connected to the XLR input and apply a -90V negative voltage to the pins of the DC DC converter.? You might have a look on my post #3 PDF with the complete schematics...
You need a voltmeter with very high input impedance.
Best regards!
Actually, nevermind using an external dangerous-voltage supply.
Just disconnect the resistor from node 7 in the schematic, and solder it (or run a wire) to either end of R10 (which goes to the input of the DC-DC converter).
You'll get a lower-than-normal level (10-20dB less), but should still be plenty to see if the audio circuitry is still good or not.
