hotfingers
Member
- Joined
- Feb 17, 2021
- Messages
- 6
I know that this unit has been discussed here previously and am hoping for a little information –
My Rac Pac has worked flawlessly for years but now, the pfl is permanently active.
There are NO individual pfl channel leds on and the switches all seem fine. As both the pfl active led and the audio pfl monitoring are activated, I'm assuming that there is a fault between the enable input of the Output 3 board and the input pin of the ASCN3-7 connector to the sub-board.
I have schematics but no voltages shown. I was wondering whether anyone might have access to the expected voltages around Q3/4/5/6 and IC39?
For reference, my voltages on IC39-A are:
Pin 1: 6.4v (hence the activation)
Pins 2 & 3: both c. 0v
So far as I can measure, there is 1mv between pins 2 & 3, if the meter is to be believed.
I'm not enthusiastic about having to take out the PCB, nor change an IC. If that is the problem, I might just snip the wire to the 'enable in' (ASCN3-7) and pull it down towards the '-' rail, simply disabling the pfl which I don't now need to use.
Any pointers would be hugely appreciated, especially the voltages around this part of the circuit.
