Biasrocks
I'm in the process of racking up a few 110A cards.
Balanced 600:600 input through a A67J transformer, unbalanced output.
I have a bi-polar +/-24 volt supply and have followed the pinout hookup directions in the 110 manual.
Pin
1 (A)
2 (B)
3 (C) -24v (B-)
4 (D) Signal Input + (Input transformer secondary +)
5 (E) Signal Input - (Input transformer secondary -)
6 (F) Signal Output - (Power supply common) (Grounded to the power supply, shields of input transformer and shield + Pin 3 of output XLR)
7 (H) Signal Output + (Pin 2 of output XLR)
8 (J) +24v (B+)
9 (K) DC Signal Output + (One leg of 10K FB resistor)
10 (L) Feedback (other leg of 10K FB resistor)
What's happening is I'm getting around 22Vdc on Pins 4,5 & 7.
I have no idea where this offset is coming from, but it's present on either side of both capacitors which should be stripping it off. I recaped, and tried 3 different cards, all with the same results.
What the hell am I doing wrong?
Mark
Pin
1 (A)
2 (B)
3 (C) -24v (B-)
8 (J) +24v (B+)
Mark
