hi I thought it might be better to start a fresh thread because a previous thread I wrote on this last year seems confusing.
basically I have an spl optimiser eq. I have attached a schematic.
there is a 60 hz hum problem.
I totally replaced most of the psu board including all electrolytics, it outputs +14.9v -14.75v. the hum remains
its possibly linked to grounding. the unit has a ground lift switch that either connects or disconnects the internal psu 0v ground rail to the input iec cable earth.
with ground connected to earth it seems most stable (get some confusing changes by holding the chassis elsewise).
the problem is quite high amplitude 60hz hum appears when you set the frequency of any one of the 4 filters to low setting.
the potentiometer for frequency is connected on one side to ground via 470ohm resistor. on schematic the frequenz pot is shown as 2 x 10k in the unit it is actually a 2x 100khz dual pot.
so setting this to low, means the wiper is at low resistance to ground. this causes hum in audio. I am not sure why.
also could removing a 10ohm resistor + small cap in the switch to ground earth possibly help (ie straight 0v >earth)?
would be grateful if anyone can help to explain this behaviour.
