Hey,
I finally got hold of a cpl of spring reverb tanks (1ohm input impedence/170(ish)ohm output impedence) and came across this site: http://homepage.ntlworld.com/henry01/spring_reverb/spring_reverb.htm which has schemos for the drive ckt n whatnot...any comments?
Also, I thought it'd be sweet to have a c/v input for the wet/dry mix control so could feed in a gate signal and have a choppy echoey type effect - any ideas how to add that in?
Finally, I'm gonna be using this box on a aux send say off the desk and run the out back into a channel - as i'm balanced from me d/a onwards, is it worth balancing the i/o or just leave as is?
Cheers!
D
Cheers!
D
