Sammas
I've got a 12v 25va toroidal that i was hoping to use temporarily while a bigger 50va 24v tranny is on its way (still two weeks til it arrives).
If i wire the two secondary windings in series i'll get 24v (wiring 12v on one secondary to 0 on the other secondary), correct? Wiring the two secondary windings in parallel will double the current... I'm pretty certian i've got it the right way around, yeah? :? It doubles the number of windings used together.
So the tranny no longer has a centre-tap? Do i just run 0 reference from the PSU board straight to ground to meet with the Star ground i have (where chassis, audio and IEC meet)?
This is part of an external PSU which is connected to the preamp enclosure via 5-core + 5pin socket. I've wired the 5-core with V+, V-, 48+ and ground... Inside the preamp enclosure, I've connected the audio, chassis and power grounds together at the Ground pin of the 5-pin socket. Inside the PSU enclosure i've taken the ground pin to meet at the star ground with the chassis, and psu (?) ground as well as ground pin of the IEC socket...
Is this a viable method? I do have a spare pin on the 5pin socket, should i maybe keep the preamp power ground seperate until the star ground in the PSU enclosure?
Wow... i hope that made some sense.
This is for a 312 type preamp that is running off 16v and draws about 100mA.
