Soeren_DK Well-known member Joined Jun 7, 2004 Messages 526 Location Denmark Dec 13, 2004 #1 I am about to finsh the Clone but i have a quistion about wiring up the Bypass switch I am using a switch and a relay... drawing i paint But what about the to last wires?? (On gyrafs schem : A2, A)
gyraf Well-known member Staff member GDIY Supporter Moderator Joined Jun 4, 2004 Messages 11,897 Location Aarhus, Denmark Dec 13, 2004 #2 ...You'll need a dual-pole dual-throw relay...
Soeren_DK Well-known member Joined Jun 7, 2004 Messages 526 Location Denmark Dec 13, 2004 #3 It is but i only drawed the first on....
gyraf Well-known member Staff member GDIY Supporter Moderator Joined Jun 4, 2004 Messages 11,897 Location Aarhus, Denmark Dec 13, 2004 #4 use com and on for the other switch then.. I hope you're not planning on using mains (220V) for powering your relay? Jakob E.
Soeren_DK Well-known member Joined Jun 7, 2004 Messages 526 Location Denmark Dec 13, 2004 #5 Why not? The relay is for 240 VAC and the switch is also for 240 VAC
Soeren_DK Well-known member Joined Jun 7, 2004 Messages 526 Location Denmark Dec 13, 2004 #6 I found a relay from SCHRACK with a main power of 24 VAC... I think i use it intead... It is a little biggere but i should could be in the box....
