It's a little deeper than that, even with the 4K. You have the computer to bypass and other logic functions need jigging. All of the channel schemos are in book 2 of 3. There is no single edge connector page, but these are your go-to points. They should be verified by another source for accuracy as I am skimming quickly over three different sheets;
Top connector, EC14
119 mic+
121 com
120 mic- ?not sure it is hole punched
126 line+
127 line-
114 mon+
115 mon-
155 group+
125 group com
153 group-
151-152 +8 Dig
141,143,144 Dig ground
145,146,155,156,159,160,167,168, plus another 10 or so pins 0vl Analog
147-148 -18 Analog
149-150 +18 Analog
139-140 -22 FETs
142 +48 Phantom
This list in no way "all there is", it is not guaranteed accurate, and is not a suggestion, implied or otherwise from me to anyone to power SSL 9K modules outside a console mainframe.
Even at $900 each, the racking is still a good deal, but I understand you don't want to chop the modules. Maybe you can make an agreement with the guy to supply the wired and labelled backplane connectors and you do the frankenrack work and power supplies? You both save time and $$.
Mike
