Recently I built a simple optical compressor:
http://groupdiy.com/index.php?topic=44550.msg731329#msg731329
So that it acted on both halves of the signal waveform, I used a pair of Vactrols with the LEDs connected in antiphase. It means you have two opto resistors connected in parallel with slightly different characteristics so overall you get some sort of average both in terms of attack/decay and law.
I have always shied away from tackling a stereo compressor because of the problem of ensuring similar characteristics in each compressor when the two side chains are linked. It occurred to me the other day that having a pair of opto resistors in each channel might provide a way round this. Suppose that instead of linking the side chains you swapped one pair of optos so each side chain operated on both channels? Here's an outline schematic of what I am suggesting:
S1, the 'Link' switch is shown in the off position. The left signal comes in via R1 and the two otpo resistors R2 and R3 attenuate it. Similarly, the right signal enters via R4 and is attenuated by opto resistors R5 and R6. Notice how the opto LEDs are wired back to back so they respond to both halves of the waveform.
When the 'Link' switch is activated, R3 is now connected across the right channel audio and R6 is connected across the left channel. In this way the control signal from each channel affects the signal level in the other. The overall attenuation should be something like the average of the attenuation created by each signal. If you have a big left signal it will cause a biggish attenuation in both left and right channels. If, at the same time you have a small signal in the right channel it will create a smallish attenuation in both left and right channels. So each channel has a combination of a biggish and a smallish attenuation; in other words pretty much the same.
This feels right in my head. Is it going t work or have I missed something? Has this been done before?
