Stuck switch on Pultec Filter
aprats
New member
San Francisco, CA
Long time lurker, first time poster. Really appreciate the help you’ve all provided over the years!
I recently picked up a stereo Pultec filter, HLF-23C, which is essentially two HLF-3C’s in a single box. 3 of the 4 centralab switches turn beautifully. One is completely jammed / stuck. Any wisdom to share on the best way to get that switch moving again?
gyraf
Staff member
GDIY Supporter
Moderator
Aarhus, Denmark
..most often grease around shaft bushing has hardened and is stuck. If metal shaft, take off knob, heat the shaft a bit with solder iron, get it turning with pliers. Keep moving while cooling down. Perhaps try to flow a bit of oil in there..
aprats
New member
San Francisco, CA
Thank you, Jakob.
Following up on this thread, I tried heating the shaft and turning with pliers, but the stubborn switch wouldn't budge. A little protected spritz of non-chlorinated brake cleaner did the trick. I then flowed in some oil and now all the switches are buttery smooth.
Spent the past couple days giving this guy a good scrub down and now it's ready for action.
