RFSiesta
Hello,
I try to solve an issue with a Studer 089 MkII broadcast console that's beeing refurbished in the studio. Andy has done great work and effort to bring back the PSU and modules back to spec and restore the sonics of this beautifully sounding board. (Especially the PWM comp/limiters are sweet)
However, we didn't get a hold of some ground problem that results in excessive noise and hum, if - and ONLY - if it's connected via patchbay, even only on one channel. If we use an external cable and cut all connections to the pb, it's almost gone. It also decreases a lot when I ground the cable shield separately.
The (newly installed) pb seems to act as an antenna, since most connections are still unused. There are no connections between channels, though.
So to mee, it looked like a big big pin1 problem, but then we checked grounding resistance: it was ~0,1Ω between shield and modulation gnd when switched off, and increased to 30-100Ω (!!) when the device was powered. Measured the other way around, R gets 0Ω. So I figured there could be DC offset and voilà: 13mV offset between the two grounds, which are PHYSICALLY connected to each other with a bridge on the outside...
Since the manual gives precise details about each module, but not too much about housing and interconnections, we're stuck now.
Next will be to try and implement a copper bar for ground and connect each Lemo connector's ground pin to it. Still have no explanation for a DC offset.
Any ideas?
Richard
Any ideas?
Richard
