The supply motor stopped in a session.
I started to go through it. I've determined that:
-the power transistors for the motor are fine,
-the motor itself is okay (when I swap the connections it spins),
-all the fuses are okay,
-The motor capacitors are okay,
-The cards are all okay (there is another A80 next to it. I swapped all cards and issue does not follow cards)
On my readings for the take up reel, the power transistors are around 190vdc, then when play is pressed, they switch to around 5vdc. The supply reads 190vdc but doesn't switch.
Anyone have any suggestions. I'm starting to run out of ideas.
