thomasdf
Hello
My mix room will soon feature a beautifully maintained 2 track Studer A80 VU which I intend to use for mix printing, archiving duties and so on.
The dedicated remotes are pretty rare, and very expensive... so I was thinking maybe I could build one from the ground up.
Since it's a stereo unit, I am thinking a transport remote would be sufficient for my needs ( being : not wanting to take my a** off my chair, lazy engineer) so it would basically be a duplicate of the tape recorder's transport. I do not need any locator feature, tape counter or being able to switch a track rec ready status etc.
Just a basic stop play rec fr ff
AFAIK (still figuring it out) my unit does not provide a input / repro switching so I would have to take care of this by building a relay switching box allowing me to completely bypass the tape recorder, as well as switch the output between an input copy or the tape output.
Anyone around here tried that ? I would like to stay analog, wired so I am not interested in a recent digital solution easily found online, which seems pretty expensive on top of that.
I will post my findings and experiments ...
This is an interesting read : https://elektrotanya.com/studer_a80vu_audio-remote_sm.pdf/download.html for starters.
Thomas
Edit : I found the pinout and schematics of the remote control. Is it that easy ? Just grounding a certain pin for a certain type of operation ? If yes, I suppose it's just a matter of non latching pushbutton and / or bistable relays depending of the functions needed.
I'd need 7 leads + ground, which means I could use a RJ45 cable for instance.
Thomas
