I recently got a C1, and it sounds excellent. Definitely my best mic for acoustic
guitar so far.
For vocals, it might be a tiny, tiny bit on the bright side, but I say might, because I usually
end up adding a small 10kHz presence bump to my AT4047 anyways.
So when I use the C1 in a mix, it's likely I won't have to EQ the high end at all.
STILL, I'd like to know if there are any CIRCUIT MODS ONLY (there is someone doing mods without
swapping capsules), that would make the high or low end adjustable a bit. Certainly the low
end might benefit from higher value series caps C4 and C3:
http://twin-x.com/groupdiy/displayimage.php?album=465&pos=0
This schematic is correct, right? I have the older model, but I'm guessing the
rest of the circuit apart from the pad and HPF are pretty much the same.
C3 and C4 are shown here as 100nF, or 0.1uF, so surely there is room
for larger caps here.
Any advice greatly appreciated....
guitar so far.
