Hi there to all of you, been reading forum a long time ago, first post here.
I have recently discovered an old box with NOS Polysterene capacitors inside, there are plenty of 680pF 630V and some other 220 or 330pF 630V i think (maybe other capacitance values also, all at 630V).
Can i use these 680pF caps instead of 470,820,220,560 ones in each cap?
C1,C4: 470pF 630V -----> 680pF 630V
C3: 820pF 500V ------>680pF 630V
C6: 220pF 630V ------>680pF 630V
C15: 560pF 630V ------>680pF 630V
... what is the range value for capacitance and volts (approx.) someone could use instead of the original ones? I mean for example, volts of C3 needs to be at 500V? What are the options if we could say we want to be more closer to its original built/sound?
I know this may has already been said here and that values may range depends on what someone want to get and forgive my ignorance as i am a bit begginer in electronics theory (my first job is pharmacist and second musician ), but due to all of you i have learnt a lot of useful things and really thank you for this.
Every answer appreciated.
Regards from Greece, peace.
