Hey Everyone:
I'm looking for some help finding a gremlin in a Summit Audio MPE-200 Mic Pre/EQ. The second channel EQ output has a problem with periodic noise and popping. It almost sounds like a static build up that begins to fizzle and get louder until it finally pops, as if it's discharging. After it pops it is fine for a while until it starts to charge up again. There's no rhythm or timing to it. Sometimes it happens right away when it's cold. Sometimes I turn it on and it's fine for a couple hours. This does not happen out of the Mic out, so I believe the problem is in the EQ or output amp section. All power rails are clean and at the correct voltages.
