Superlux S502 MK2 test, teardown and improvements
I think it has been discussed on the forum : a very good solution is Takstar CM63 + 3UAudio capsule(s) > 42€ + 120€ to get a really nice cardio SDC...
@Recording Engineer let us know please when you receive the 92€ Ali SDC mic (Schoeps look) and how it sounds with the chineese original caps.
Sure! There are a number of really usefull mods described in this thread, nicely summarized by @Voyager10.
You specifically mentioned to pair the CM-63 with the 3U capsules, but it yields a slightly different tonality when compared to the CM-60 + 3U combo, which I liked better. It's a bit flatter in the highs. I assume the differences are caused by the different back chamber and slots design. I'd suggest to also consider the Alctron T-02A instead of the CM-63, which I expect to sound identical to the CM-60.
You can hear the tonal differences in @joulupukki 's Blind Test (link below). Though both the CM-60 and CM-63 have slightly different KM84 style circuits, both circuuts are dead-flat in the highs, so I'd reason that tonal differences in the highs should be caused by the capsule/body combination.
Thread 'Four KM-84 Clones - Blind Test' https://groupdiy.com/threads/four-km-84-clones-blind-test.89135/
Having done the KM84 "project", the S502 Mk2 capsule similarities with a Schoeps MK4 triggered me to pick up cloning a CMC6 MK4 as the next project. Just not with a standard Schoeps circuit, but my own.
Jan
@jp8 your DIY seems very attractive... so after a "Jan S502 special circuit" we'll have a "Jan Schoeps custom build" ?
Great ! Oh, I forgot Xmas is approching (Santa Jan) ;) 🥳 (y)
Thanks a lot for the kind words, @Emmathom ! 😊
The "S502 special circuit" should be credited to @MicUlli , though. The circuit that I had in mind for the Schoeps MK4 clone SDC has charge amplifier input, CMOS polarization voltage generator and improved Schoeps output stage. Not a 100% Schoeps clone. Has more headroom, somewhat lower noise and THD compared to the "standard" Schoeps circuit that we all know.
Jan
Jan
So, a kinda "to-do list" :
- use my S502 capsules for your DIY Schoeps circuit (but the right body has to be found for that) > what to do then with the mic without its capsules ? Waiting to find a mic out-of-order and use the capsules maybe...
- buy a S502 MkII and replace the original circuit by @MicUlli one (about 145€ + 35€)
Maybe resell my WA84 pair to finance that ? (lowest price brand new is 606€ so I could resell ~500€)
or keep them ;)
