Superlux S502 MK2 test, teardown and improvements
As for the coupling ring, I was already thinking that this would be a best solution.
I wouldn't fix it with expoxy though. Conductivity again šŸ˜‰
Either make it a touch oversized on one end and screw in the body while frozen or just use a tiny dab of a thread locking compound - Loctite or similar.
Yep a ring... or cut the "head" and adapt it to a body. But I'll be able to see more clearly when I get my mic MkII...
    195 KB
Yes.
The process forms a hard, very resistant oxide(Al2O3) layer. Much more resistant that forms naturally. Which is also electrically non-conductive.
So... (it's not clear) do you NOT recommand adonized aluminium ? prefer brass ? (over other metals)
Do you mean that because of the 3 wires of the MkII capsule (plus / minus / ground) conductivity has to be from capsule to XLR thru whole body ?
These completly different techonlogies from 1rst to MkII version is getting me a bit headache (why did they change everything damn !)
Hmmm... I used to vape. Before the bases became ridiculously overpowered electronic laden devices.
Just a tube for a 18650 akku (or two) with a mechanical momentary switch.
I just went and dug out what is left of my stuff.
A brass tube 22 mm diameter, 2,5 mm wall thickness, threaded inside at both ends (regular thread), 19,5 mm inside.
Rings a bell?
Ready made and cheap (10 bucks or so).
The one I have left (photos) is too short but I had longer bodies.
I'd have to search my aging memory for the site net address and check if these are still aviailable.
Of course it'd need a screw-in XLR adapter/holder made. Which could make this whole exercise too expensive versus a body made from scratch.
Needs investigating.
    2.6 MB
    1.7 MB
Yep a brass tube like 22mm outside and 18mm inside to be machined correctly (not an issue). But the diameter of the capsule thread (19,2mm) and the diameter of the interface (18,8mm) leaves only 0,4mm of materiel which is thin (too much I guess). So back to a "kunction rig" maybe... So yes it needs reflexion and more investigations
(XLR can be held by a screw like most of the SDC and a dedicated hole in the body)
Every aluminium part in open air will oxidize. Well known. But that does not mean it is totally unusable, though I guess brass is better. Isn't the MXL603 made of aluminum? OK, I cut my finger on a burr on the threads and capsule does screw on smoothly. But electrical contact is sufficient if there is enough contact pressure which pierces the oxide layer and the pressure seals the contact against new corrosion. Aluminimun is even used for high-tension, high-current wiring. Even nickel has an oxide layer that has to be pierced for proper contact.
Jan
I think very few mic capsules/body threads are aluminum; if not brass they are usually nickle or in cheap mics, so-called pot-metal.
I've had all kinds, and the only issues I've ever experienced is easy cross-threading, or binding - but never electrical contact so poor that caused any audible problems. The act of screwing/unscrewing clears any tiny amount of oxidation.
I think Oktava's body is "pot-metal" (very thin) but the thread is different. More strong, It shines and looks like stainless steel (but it ain't steel). Maybe brass ? Its color is silver xith a tiny amount of gold coloration.
About the body project we stand on brass until further information. No more aluminium considered. We thought (not for long) about carbon pipe (very light & strong) but carbon is way too much sound conductive ! Metal seems to be unavoidable...
The MK012s I bought in the early 2000s have brass threads; I assume the body finish is some kind anodization (it's quite tough; not paint).
I'm asking again :
Did one of you already try a Superlux MkII capsule on a Schoeps prƩ ?
Yes, see pic. So 2 dB softer than my MK4, but between MK4's there is often also a 2 dB margin. Bit of drop off in the lows. Measurement not in an anechoic room!
    83.6 KB
i want to draw your attention towards a trick. ORTF recordings with cardioid capsules sometimes have a lack of low frequencies. This is a drawback if you want to record for example choir+organ. For the S502 MKII it was tested and proven to work well.
Simply add an omni mic (well known for deep bass response) to your setup, place it in the mid of the ORTF capsules. Then do a mix in your DAW:
Apply a 1st order highpass @ 70Hz to both ORTF signals AND a 2nd order lowpass @ 70Hz with Q=0,5 to the omni signal. Then subtract the resulting omni signal from both prefiltered ORTF signals. The resulting omni signal must be adjusted carefully of course. Then you get the "space" from ORTF combined with the "depth" of the omni..
BR MicUlli
Hello everybody, I'm an unlucky owner of a S502MKII from 2020 with uber high sensitivity to radio magnetic interferences (see spectrum capture attached). I also own a S502MKI wich doesnā€™t have this problem. My setup is clean, simply switching from the MkI to MkII brings the interferences. I can manage to lower/avoid those interference on the MkII by adjusting mic placement and recorder position relative to mic, but it remains unusable for me.
@MicUlli I would be interested in 2 boards, do you think the new boards would solve the interferences issue on MkII?
    1.2 MB
