Rob Flinn
Having looked at the SSL website they state that they use switch mode psu's for everytrhing now. In fact the whole SSL corporation has pretty good green credentials & they have an interesting page explaining their philosophy. They state quite rightly that the switch mode supplies are less wasteful of power.
Anyhow, what got me thinking a bit more about this is that today I was asked to look at a Siemens C4 console that a friend has recently purchased. It was supplied with a psu made buy a company naming itself Velvet Audio. The previous owner had not actually hooked this up, & part of my work was to sort the power loom out to connect it. I opened the PSU box (a 2U rack) to discover about 5 generic switch mode PSU modules, each of which had an additional large cap strappped across its o/p. I power the console up & the 2 supplies that were for the + & - 15v became over stressed & collapsed to around 6v each & you could here motor boating which became worse the more channels that were installed. The 24v relay supply also became unstable, & I could here the relays turning on & off rapidly. In the end it would only behave normally with 2 channels in the console.
So is it the case that the load in this console is just too inductive/capacitive for these switch mode supplies to deal with, which explains them collapsing under load ? Would it be better to construct a linear supply, or is there a way to get them working with this console. I think remember reading that SSL use switch mode supplies but they have linear regulation afterwards, & since they are using them it's obviously not impossible to use them.
Any thoughts /
Any thoughts /
