Hi everybody, ;D
I have a technical question I hope you can answer
I am planning of building 2 different stereo line amp card with both the same type of transformer on it.(input and output)
I would like to avoid buying 8 transformers…but 4 only…
I planned to use a relay system that would “switch” the transformer from one card to another and then switch the “global output” to have the choice between the 2 card (one OR the other) and the transformer will “follow” my choice
I there any “risk” doing that (except a “pop” in the sound I suppose…. Anything else to consider ?
Hope I describe it clearly.
Thanks a LOT for your advice
Phil
Phil
