letterbeacon
Currently I have two linear power supplies in my DIY modular synth. They work well and supply clean +/-15VDC to my system, but they are physically heavy. I'm looking at making my modular more portable for live performances and have started considering switching power supplies.
When I first started building my modular switching supplies were frowned on -too much noise. But I've noticed recently that some modular synth companies are offering switching supplies commercially with good results. Take for example the Tiptop audio Zeus system: http://www.tiptopaudio.com/zeuspwr.php
I think this is how it works:
It takes 15V from regular laptop switching power supply brick, feeds that into what looks like two DC-DC convertors which clean up the switching DC and turns it into +/-12V. Now my knowledge on DC-DC convertors is pretty limited, but I think because they switch at much higher frequencies than the laptop brick, it means the noise is inaudible to the ear. Also as the brick can be positioned away from the synth, the interference generated by it doesn't affect the synth.
At least I think that's the theory! As I say, my knowledge is limited so someone please stop me if I'm way off here!
My plan is to build something similar. I could just buy the Zeus, but it doesn't supply the +/-15V that I need, and the connectors aren't compatible with my DIY system so I'd end up modding it heavily.
My plan is to take a laptop PSU that outputs 18VDC and feed it to two DC-DC convertors that will output the +/-15VDC that I need.
I was thinking of using something like this to give me the +15VDC: http://uk.mouser.com/ProductDetail/Cincon/EC7B-24S15/?qs=sGAEpiMZZMtwaiKVUtQsNZk%2fyhBUJKktSIxQ6LwPsOs%3d
I can't seem to find much on the net about best practices when using these things. Do I literally just feed the DC-DC convertor +18VDC and I get +15VDC from the output? Do I need to filter the DC at all? I can't seem to find any application notes at all!
Would someone be able to point me in the right direction about using DC-DC convertors, and to let me know if my theory above sounds about right?
Thanks a lot!
Thanks a lot!
