phantombox
Member
- Joined
- May 4, 2012
- Messages
- 23
Hello guys.
Someone gave me a Symetrix 501 to see if I could fix it. It started to get noisy...
My guess is that after 30 years, a recap job would be in order. I did some research on the internet and could find some things but nothing specific to my problem.
I could not find the right schematic for this compressor, all there is on the internet is a schematic of the latest version that has an output transformer.
Mine has no output tranny. The one I have is grey-faced, has push buttons, a blue Valley People ECC101 VCA, another 16 pin IC IRC-8703 (no idea what this is, I couldn't find anything about it), and 7 pcs 4560 op-amps.
I already "cranked up" the PSU (diodes over the volt regulators, 2200uF caps instead of 470uF before the regulators and 220uF instead of 4.7uF after the regulators) and shorted out the 2 4.7uF 63V NP input caps which apparently aren't really needed. There are 5 more 4.7uF 63V NP caps in the circuit, and I'm having trouble finding them for a reasonable price. The guys here want 2+ bucks for each cap, and they are not even in the area that I live. Seems that the damn caps are quite unique. Do they have to be this value or can I use larger caps (like 10uF even 47uF)?
I also tried with other op-amps like the TL072 or TL082, even NE5532, same noise pattern. I cannot find any OPA1642s, as someone said these would lower the noise floor a few dB.
Any suggestion is welcome.
Thanks in advance.
Thanks in advance.
