TAB H 381B SCHEMATICS!?
DRUMREC
New member
Stockholm-Sweden
Hi DIY Friends!!
My first post here  :)
Is there a friendly soul who can help me with schematics,datasheets,diagrams for TAB H381b.
Something so i can wireing up my  TAB H381b. Can not find information about TAB H381b anywhere!?
Someone...
Kind Regards
H.Hansson
This is a picture of the TAB H381b:
It should be easy to deduce the pinout by following the pcb traces. You need to find out power input and audio output.
The ground is usually the largest trace area on the pcb. The power supply is +24V and goes from the connector to a regulator circuit on the pcb.
There is also similarity with the modules from the same manufacturer having the same type of connector (power pins at least). Check this:
http://audio.kubarth.com/rundfunk/index.cgi
Audio output is probably taken directly from the transformer secondary.
