Wanted to document my progress so far, deliberately keeping things about as unsophisticated/simple as possible:
I mostly post guitar pedal stuff on that channel historically (other than my music), so the circuit explanation is geared toward that audience. I think most folks here can just skip to the end of the circuit drawing sections if you're curious about specifics, but both circuits were a 2M2 gate resistor on a FET input; one uses a transformer and the other is the Alice (Schoeps) active output. The transformer is a little UTC transformer I bought here years ago that I've never really decided on a use for. An old thread about them says they can handle -7dB, so I was originally planning on using them in something that would intentionally drive them too hard, and just never got around to using them. I do actually like that it steps down the level a bit, as the Alice circuit is almost too loud, but I'm pretty sure I can find a cheaper (and maybe even smaller) 1:1 or 2:1 transformer for this purpose.
I've drawn part of a layout from the link L´Andratté sent, so I do plan to build one that's op amp based. I also want to try one of the THAT chips for an active output and see if it improves S:N. I've also drawn a layout for the Bo Hansen, but I'm not sure I want to bother boxing up another transformer-based one. (Of course, I could always desolder the circuit board from the box.)
However, I will say: I'm impressed by the sound of the Alice microphone circuit here. The highs are
extremely clear, even compared to another circuit with the same input impedance (the compression in the video might not make it clear how dramatic the difference is). It does seem to pick up a bit more noise, which I mention in the video. Before I soldered things up I did try one version of the fake ground lift (from the Bo Hansen box, with the small resistor, capacitor, and two diodes) on perfboard but my crude measurements didn't show much of a difference. Of course that was outside the box on the breadboard. I might go back in and put it between the XLR and circuitboard to get a better idea.
Not much to look at on the outside -- I'll give it a fun graphic once I think I'm satisfied with what's in the box.
https://www.dropbox.com/s/7ou1ptnnbyqwyh1/direct box guts.png?dl=0
