Arno said:
Any comments, suggestions for 'improvement' ?
It seems to handle 600R load trough a 1:1 transformer, but since it's relatively low psu voltage (+21V) headroom might be a problem (?)
I don't think it can drive a 1:2 on the output. How about increasing the 21volts?`
Any consequences as long as the transistors can handle it?
How do you calculate the max voltage swing from a "dual emitter follower" output stage like this
The output capability depends very much on the load. Particularly if the resistor R1 is 470R. If this resistor was smaller, this output stage is relatively capable of delivering some current (about +16dBu into 300R, +18 into 600R), but with the resistor, there will be as much voltage lost in it than available to the load. Reducing it (making it 47R, as R12 for the 1st stage) would help, but anyway it is a single gain-stage opamp, and trying to load it will reveal some THD.
And definitely, loading it with a 1:2 xfmr is not a good idea.
I think your idea of increasing the supply voltage is worth investigating; you may have to rebias the FET, but there's already a trimmer so it's easy.
I don't see any reason why you could not increase the voltage to 30V. That would give a max output level comparable to most equipment powered with +/- 15V rails.
Beware that the output stage is not protected, though.
OK, how to calculate?
The
unloaded output swing is rails voltage minus 2Vbe
Rais voltage is 21V minus R1.quiescent current
Quiescent current is very hard to determine here because it's governed by the difference between Vbe of transistors and Vd of diodes.
An estimate of 10mA, would make the rail voltage 21V - 4.7V, and output swing 21 - 4.7 -1.4 = 14.9 this is 5.2 Vrms => +16.6dBu
If the resistor R1 was much smaller, say 47R, the unloaded output swing would be +18.8dBu
When the output is loaded, the limiting factor is the current the resistor R22 or R20 can inject in the base of the NPN transistor when the output voltage is high. This, combined with the Beta of the transistor, will determine the current delivery.
