Tech docs?
fazer
Elizabeth
Maybe there is an explanation elsewhere I have not seen, but. I only see 15 threads in the technical section. Is this new software build just slow to capture all the old material? Any estimate on when the rest will be available?
I must be doing something wrong it shows 285 and when I play with the filter it seems to find other stuff just not sure how this works yet
There are 15 pages of Tech Docs. 14 pages at 20 threads each and the 15th page has about 6.
So that is roughly 286 threads of tech docs.
At the top over the list of threads you will see page numbers.
If you look at the bottom of the first page of docs you will see page numbers.
If you want to see one of the numbers that is not in the list, just click on one of the numbers and it will bring up that page, but also a box where you can type in the thread number you want to look at.
I can see all the 285 threads of tech docs.
Could use a cleaning as I see some threads as individual pieces that can go under main threads related to the manufacture or repeat in manufactures that can condense into one. However I wouldn't even know where to begin in assisting in that
