Go to BAMA, download the manual. There should be a Basic Checks page.
The main problem is that there are too darn many knobs and switches. The manual should give you a Basic Settings which will give you "a picture". From there, if the 'scope probe is grounded you get a horizontal line; if probe is fed from the CAL jack you should get a square wave (will have to adjust width and height); if probe is held by by a guy not touching ground, it should show a messy sine-wave (all the electric hum and buzz in the room).
Focus should work. Astig is a secondary focus. Do NOT turn BRITE full-up, keep beam strength somewhat below maximum (for best focus and also for good screen life).
