tomom said:here is the picture, not the best quality...how will I figure out which of three wires on the three pin connector has to be connected to where..can you sketch connection to 100 volts and transformer?...Thanks Tomo
MS Vienna said:As for diaphragm donor: the C14 diaphragm is only approx. 45 mm wide. That´s too narrow already to be used in the tensioning device for large diaphragm capsules. 60mm width minimum is needed for proper results. You can leave those C14s intact.
