I recently bought a Telefunken V 672 with option for another.
When I first tried to use it as a mic-pre I couldn't get any low end out of it.
I used an EV Re 20 and compared the signal passing the V672 and then into the line in of a Mackie VLZ to the signal going directly to the mic in of the Mackie.
The first problem was that there was some awfull hum when I didn´t put the Signal Ground to the 0-Volt of the Power Suplly altough the manual says that there is no connection beween the housing (Signal GND ) and 0-Volt.
When I connected Signal Ground and 0-Volt, the hum was almost gone, but still the amp sounded quiete noisy.
Another problem was that no low frequencies seemed to be passing the module.
Meanwhile I replaced all caps against new ones, which helped.
But still even the Mackie preamp has a lot more low end.
Has anybody some ideas what the problem could be ?
Has anybody already racked one of these modules?
I'd like to build a rack containing two V672, a 24V DC power supply, a 48V DC power supply for Phantom Power, a phase revese, an instrument in and probably some VU-Meters.
Maybe anyone could come up with schematics.
greetings from Austria
(please excuse my english)
