pucho812
Have several doa's that we have been testing at work. Some are the obvious ones like a 990 and a 2520 while a couple others are discrete designs that are not common(well known). What I am trying to figure out is this. Using the AP system one and our five fish audio opamp test jig, the opamps tend to perform similarly to one another. There are differences in things like THD and noise on the different opamps which would be expected. What I found interesting is with the same settings the opamps behave very similarly to one another in terms of frequency response having differences that are minor, less then a tenth of a DB usually. In fact the big differences are THD and noise as one had a spec of -90db while another had a spec of -80db. This is with sweeps of around 0dbu. However when taken off the test jig and used in circuit, a 312 style pre, they all behave much differently and an audible difference can be heard. Again same settings all around once using the same pre amp channel and once using multiple pre amp channels with matched settings. No one knew which was which but they all agreed there was a sonic difference between opamps.
considering the AP says they close enough in terms of behavior, what would explain the noticeable sonic differences? Or is it all like psycho acoustics and perception?
