Water heater elements can make decent loads, and you can boil water to scrub off some of the energy.kambo said:i need to test a HiFi amp 120W / 8ohm, for 24 hours, see how hot its getting etc, at full volume...
cant play it that loud!
can i just slap a 8ohm/160W wirewound resistor, and let it run for 24 hours!
JohnRoberts said:Water heater elements can make decent loads, and you can boil water to scrub off some of the energy.
Depending on the amp design, it could get hotter at 1/3 power than full... but I guess it depends on what you are testing?
Modern amps have not been designed for continuous duty 100% output for several decades now.
The heat dissipation depends on the amplifier topology... class A/B is worst case for heatsink at 1/3 power. Class D will be roughly linear heatsink dissipation with output power. Class G/H will be somewhere in between.kambo said:heater element was first idea, but readily available resistor very tempting,
cant read the chip on amp, but nothing complicated...
will check at 1/3 too, good to know that, thank you.
