timpanic
- Joined
- Jun 18, 2013
- Messages
- 48
Hi folks. I have a question and maybe somebody knows.
I built a micpre based on the usual schematic from the THAT documents. Simple 1512 with the usual diodes, caps in front with rf filter and a 1646 as output. Also pcb grinder etc used this design. Can also be found here a lot.
As rf filter I tried the 100pf and the 470/47p combi.
The issue is that when I combine more than 2 channels the channels began to produce noise/hiss at high gain settings. Especially when nothing is plugged in. When a mic is plugged in a noise is also there but it seems the channels interfere with each other at higher gain settings.
When I reduced the amount of chips installed in other channels and only use one or two channels the problem is gone so it seems they start to oscillate when more ics are plugged in but the voltage rails are all fine. Again each channel on its own works fine when no ics are installed. The 100n caps beside every ic are also installed.
BUT when I put a 100n wima cap over the + and - input lines, directly at the xlr connection or somewhere on the pcb before the 1512 chip the noise is gone completely.
So what is wrong here. I found a schematic for a single rail psu layout where such a cap was placed but with a lower value but this doesn't filter out all noise for me at the highest gain setting. I saw 8 preamps in 2he with this project with the same schematic so I wonder baldy what should be different there.
Til now every four channel preamp I built behave that way. Only when I build only two channels the issues does not appear.
Does anybody who has built any of the 1512 designs have an idea or any suggestions?
