electric_diaries
Hi all,
I got some THAT4301s the other day and went about making a test circuit.... but I must be doing something stupid.
I am powering it with +/-12V and using the circuit below . At lower volumes I am only getting distorted positive cycles. Then at a higher volume there is a threshold where it tries to jump to it’s positive rail.
Sorry I can’t provide more specific information on where this threshold is because I was using someone else’s test equipment. However I managed to make a small audio clip of a 200hz sine wave that is temporarily pushed into this threshold. (lets assume this threshold is somewhere around +4dbu to give you an idea). I will post a picture of the waveform in the first comment.
I tested OA3 and it appears to be working properly. I can see the proper voltage on pins 10 and 11 and have tried connecting pin 16 to a high impedance voltage source, ground, and no connection.
I also tried changing the chip so I must be doing something stupid with my circuit.
Any ideas where to start looking?
Many thanks!
Many thanks!
