Reply to thread
Good point. Worth repeating
Extruded cases with front and rear customisable cases are OK for many projects and there are lots to choose from, but if you want a top surface and rear surface to both be customised, there seem to be no real off the shelf choices at all (unless you know otherwise   :) ).
Edit: One thing that did occur to me was that it should be possible to make a 3D model of a plastic box which has a top and rear cut out which could be fitted with aluminium panels. The box could be made any convenient size and printed at home on a 3D printer and the panels customised like any other front panel. But I have no idea if such a home made plastic box is feasible.
