byoung
One of my Dynaudio Bm6a monitors had a catastrophic issue and just fuzzed out (it's not the relay, I've already dealt with that a couple of times). It became really distorted and then stopped passing audio. When I first examined it, I was getting low resistance on one of the mosfets so I replaced them all along with their resistors and transistors as per the service manual recommendation. I put it back together and it is still blowing it's two fuses for the +45/-45v lines. The +15/-15v(preamp) lines still seem to be functioning fine, the AC transformer seems ok, its just the power amp blows it's fuses instantly when I turn it on. I noticed at the airpax switch heatsink/ground connection that I was getting continuity when I shouldn't be based on my functioning speaker, so I realized I had a short, I swapped the airpax switch as well thinking it may be the problem... but it wasn't. There is still a short in a component somewhere and I haven't been able to locate it. I suspect maybe a electrolytic cap or diode failure, possibly one that only shows up when power is applied? Any thoughts on how to find the bad component with a multimeter without being able to power it up? There aren't too many parts in the +/-45 circuit so I'm hoping somehow I can find it.
