Che_Guitarra
I'm building a Drip Opto 4 LA-2A - it's almost complete apart from a couple of resistors and the hookup of the off-board parts. I'm wondering if I could get away with mounting the power trafo inside the case so I can keep the depth of the unit in check? Or would this be strongly advised against? The case is already 11" deep, with an externally mounted PT it'll take the unit to 14" deep.
Here's my case and the approximate floating position of the PT:
What do you suggest I do?
