Marco Pancaldi
Active member
- Joined
- Feb 19, 2006
- Messages
- 36
Hi.
if I have a 200 ohm nominal out impedance passive mixer, connected to a step-up transformer with 1:4 turns ratio (12 dB gain), what is the minimum load impedance for the transformer output?
I'm not sure of my calculations, as follows: 1:4 turns will be 1:16 impedance ratio, so 200 X 16 = 3.2k. If I use a "matching" impedance load (3.2k input Z), I have 6 dB loss, and the total gain (+12dB step-up transformer AND -6dB transformer loading) will be 6 dB total.
To minimize voltage loss I will need a "bridging" (1:10) of minimum 32k.
Is it correct or I'm wrong?
many thanks
m.p.
many thanks
m.p.
