Is this a good aproach for a mix pre... I have an ADA8000 and I'm thinking in taking out the pres, but I don't have any other to use there in portable studio, I travel with my macbook, a m-audio and this to record 16 track, sometimes live, I use the preamps from the console I use in the place, but when I'm in a garage I need small pres... I didn't take them out because I'd like to have some pre and a direct input that doesn't uses the pre,
My question is if it is a good type of pre what should I do to make it work better? Making a recap would help or is there something else like improve the input transistors or other thing? the A06 are SMD so would try first changing the 1316 to BC560... Any tips?
JS
PD: the other option is to take away the whole input board and make some small pre to fit in there, maybe something like green pre but using as 3rd opamp the one that is already there, PS mod would be needed to drive 8 NE5532 too. Other option is the pre of the Allen Heath GL2200 that uses just 2 transistors and half TL072 but to avoid changing the SMD feedback resistors I could take down all the values and with more current I'd get lower noise and no need to mod the PS.
