it's the average voltage that causes heat, minimum voltage that leads to dropping out of regulation.yes indeed, however if the issue is too much voltage being dropped across the regulators (leading to excessive power dissipation and heat), then if feels unlikely the approach would be problematic, although I'm sure a weather eye on the voltage rails when the desk is running at full load would be sage.
dropping the C will increase the ripple voltage a proportionate amount. Whether that affects noise floor depends on the circuits PSRR.I hadn't thought of that ... ... but isn't it also likely to induce ripple noise
Higher ripple voltage but ripple current will be pretty similar (ripple current is an average heating phenomenon also).as well as reducing the MTBF for the smoothing capacitors because they're now seeing far higher ripple voltages and thus greater ripple current?
many ways to skin every cat..You correctly note it'd also reduce the drop out voltage but by how much is probably harder to calculate whereas the diode is quite predictable from its forward volt drop.
Great example of different circuit designs which achieve the same result though!
Another way to scrub off excess transformer voltage is a resistor in series with the transformer winding (before the rectifier)... I used the resistor trick in a small headphone amp that drew too much current if I connected it to drive a loudspeaker. The headphone amp was happy driving a loudspeaker load ( perhaps over designed) but it would overload the thermal fuse in our 1A wall wart. Adding a small resistor in series with the transformer effectively power limited it so the wall wart would not melt playing loud into a loudspeaker. The headphone amp was not intended to drive loud speakers but I routinely did that at trade shows, because I could.
