Triad HS-54 replacing Triad HS-52 ?
1dddream
New member
Hello
Thanks in advance..... Does anyone know if the Triad HS-54 can replace the Triad HS-52 for vintage audio designs ?
And another applicable point of interest would be what kind of audio design would best be suited for the HS-54
Thanks again for your time !D
max level is 26 db or the hs 52
max level is 10 db or the hs 54
probably due to the P5 vs P1 sheilding,
P1 is 1 nickel alloy shield good to -45 db shielding
P5 is 3 nickel, 2 copper, good to -95 db shielding,
extra sheilds take up space in the same size can for both,
so i bet the core is smaller on the hs 54.
hs 54 good for bridging, single or push pull amp,
pri  20k/5k
sec 600/250/150/62.5
use it for a low gain mic pre, like a 1 bottle or a tele v72,
