ricothetroll
I'm currently troubleshooting an Orange Tiny Terror 500 amplifier. This one has a switched mode power supply, and a class D power amp (500W for less than 5kg !!!!).
When I switched it on, the fuse blew right away (exploded actually).
I found a bad cap (3300uF/16V electro) and the two MOSFETs are shorted, whatever direction I test them (every combination of the 3 pins beeps with my DMM).
The PSU provides two bipolar supplies (+/- 15V and +/- ???V), and supply for the preamp tubes (HV and 6,3V).
I have 3 questions :
- Are the two MOSFETs dead ? I don't know them mosfets too well....
- The MOSFETs are FQA28N50 (Vdss(max) = 500V, Id(max) = 28,4A, Rds(on) = 0,16R @ Vgs = 10V).
I can't find any FQA28N50 in Europe but RS Components sells FDA28N50F. To me the specs look qui similar but again I'm no specialist in SMPS. Do you think those can be an adequate replacement ?
- When those MOSFETs burnt, what other component could have been burnt along with them ? (the most probable...)
Here are pictures of the PSU :
https://dl.dropboxusercontent.com/u/28610725/Tiny%20Terros%20Bass/DSCF2295.JPG
https://dl.dropboxusercontent.com/u/28610725/Tiny%20Terros%20Bass/DSCF2296.JPG
https://dl.dropboxusercontent.com/u/28610725/Tiny%20Terros%20Bass/DSCF2297.JPG
https://dl.dropboxusercontent.com/u/28610725/Tiny%20Terros%20Bass/DSCF2298.JPG
https://dl.dropboxusercontent.com/u/28610725/Tiny%20Terros%20Bass/DSCF2299.JPG
(the two mosfets are already out of the board and the 3300uF/16V cap replaced by 3x1000uF + 470uF in parallel)
Unfortunately I couldn't find any schematic so I don't even know what kind an SMPS it is (flyback, buck boost....)
Best regards
Eric
Best regards
Eric
