I am interested in building a tube channel strip (preamp, compressor and EQ) I can see the advantage of one unit instead of 3 separates, saving on 2 psu’s and additional input/output transformers plus space saving. I don’t have a clue how to design my own but I was curious whether any of the projects here could form the basis of the channel strip and adding the missing components.
I realise this is probably totally impractical or require extensive redesign but if I don’t ask I’ll never know.
Compressor Route
I read a post which said an LA2A can work as a Preamp/compressor by simply adding the usual mic inputs, phantom, phase circuitry etc before an input transformer. Is that correct? Is it that simple?
Would that work with other compressors eg D-AOC?
Preamp route
This is my preferred route. Could a simple opto compressor circuit be integrated into a G9 pramp? I only want a simple vactrol based compressor (one knob) with a HPF side chain and possibility of stereo link. I’ve seen some circuits described here, but how easy would it be to integrate them into a G9?
EQ
In either case could you simply add EQ eg EZ Helios or passive section of G-Pultec before or within the output stage or does it all have to be carefully matched? Inter stage transformers or circuitry or even another amplification stage?
Compressor Route
Preamp route
EQ
