mitsos
- Joined
- May 4, 2007
- Messages
- 2,886
OK, first, sorry for the ramble, and nobody pull a gun on me for tearing up an old Ampex. I didn't do it. Just trying to help a friend with an already torn up piece of equipment.
Yesterday I was asked to help with a couple of Ampex 601 channels. Just loose modules bought on evilbay ages ago. I believe one was bought already "modified" for use as a preamp (basically has an IEC socket and had the cable harness that connects it to the tape removed not much else has been done that I can see), the other is stock, from the looks of it. I am against breaking up old equipment as much as anyone else, but this guy is a friend and he's really nice, so, I'm not going to give him a lecture on ethics or historical value. Not yet anyway.
Anyway, the one he's using has a bit of 60Hz hum (way below the signal in actual use, but I think he is wanting to use it on quieter sources). I checked all the caps and so far they all test within spec (except for one cathode bypass cap that reads completely open). But that valve isn't in the circuit in actual use, it's part of the tape playback.
The thing has AC heaters and they're not wired in any systematic way, so I'll look into that first.
But my gut tells me to clean this thing up by pulling out the unused circuitry (V103, V104, V105, and V107 and related passives) and hardwire it the way that it is being used, move the Rec Cal pot to the front as an output level, and rework the PSU filters to give the specified voltage... It'll help make room under there and make it easier to see what's going on, besides not wasting those valves for no reason.
I'd probably swap the sh*tty-looking output transformer for something real-sized (stock one is really tiny, would probably fit inside an OEP case).
One question: Is there any benefit to changing the 5Y3 to solid state? Also, this thing is rated for 5V heaters but is getting 7V. My thought was to use SS rectifiers, and use this winding with a multiplier for a phantom supply. Am I right in thinking that removing this AC from the DC side of the rectifier would also make the filters more effective, in that there won't be 5-7VAC to filter out?
Soundwise, I've heard this exact channel on bari sax and it was really nice in context. Having played with it a bit, it wouldn't be my goto pre by any means, but in a larger recording, it definitely can be useful.
thanks to anyone who feels like chiming in. Just want some confirmation that I'm on the right track here, and if anyone has any experience with these things it's be cool to hear. I found a couple old threads, but got a warning about posting there cuz they're 2+ years old.
