Tube mic wiring... can't find pinout for Avant CV-12
Sorry, to be more specific I'm looking to make a 7 pin XLR cable for it.
As an example for another manufacturer with Mogami wire:
1. 200v (constant side of bias) Red
2. 6v  (heater) Green
3. 0-200v (bias) Purple
4. signal ground (balanced pin 1  [on psu's 3 pin xlr output]) Ground
5. - signal (balanced pin 3) White
6. + signal (balanced pin 2) Orange
7. ground (centre pin of the 7pin connector) Ground
on Avantone PSU PS-12 (delivered with Avantone CV-12 microphone) 7-pin XLR is:
pin 1 bias 1 (constant)
pin 2 bias 2 (from characteristic selector)
pin 3 heater 6V
pins 4 & 7 (and body of XLR) are connected to chasis
pin 5 signal cold
pin 6 signal hot
I hope this helps
regards, Ivica
pin 3 heater 6V
pin 5 signal cold
pin 6 signal hot
I hope this helps
regards, Ivica
So 4 and 7 are both ground, and connected to chassis?
connection to chasis is made thru body of XLR, and there is one wire that goes to PCB ground from pins 4 & 7.
i'd send you a photo, but I've returned mike this evening.
It had some issues in capsule circuit, and had making noise like "cooking" for about half hour. after that worked silent.
it was problem in assembly...
annyhow, this microphone works really great, especially for that price... I'm still schocked haw good it is
pin 3 heater 6V
pin 5 signal cold
pin 6 signal hot
I hope this helps
regards, Ivica
Hi, I'm trying to put this cable together tonight, and I got a reply from Glen at AVANTONE, indicating the pinout is actually different to the above scheme, specifically 2 & 3 are reversed.
Can anyone confirm having tried this?
I don't wanna do this the wrong way and fry anything, least not myself!
From GLEN at AVANTONE:
The actual signal pinout is:
1                    150V
2                    Heater 5v
3                    Capsule pattern bias
4                    Ground
5                    Output+
6                    Output-
7                    Ground
Best,  Glen Heffner
Oh, and you can see he's indicated pos and neg the other way around, too.
Evan
