G
Guest
Guest
on Neumann web site I find the following post. Can somebody explain how to made circuit for that:
Have you ever heard a U47 which makes some strange noises, which could be described as crackling, crushing and swishing, all at the same time? Sounds funny, but is only usuable if you look for special effects. Chances are you hear the 'crushing-' and 'twinkling-effect' (Schrot- und Funkeleffekt), as described in old tube manuals. Andreas Grosser from Berlin told me so. This effect is caused by underheating the tube over a long perdiod, or by using a new tube which has not been burnt in. (I am no technician, so I hope I got this correct.) The Neumann U47 gives the VF14 a heating of 35 Volt, however, the tube is constructed for 60 Volt. So there is an unterheating of 42%, altough Telefunken only recommends 5% under- or overheating. This may cause the cathode only glow at the tip and electrons escaping arbitrarily, causing the crushing and swishing. Now, there is a solution for this. The tube simply has to be slightly overheated (5%) for at least ten hours, with 200 Volt at the Anode. This is a simple circuit, or it can be done with a tube tester. My technician has done this for me, and now the U47 works fine. Many thanks to Andreas Grosser!
I had the same problem with an UF14 before after using it about two weeks and which also was underheated. But now I stay with the VF14, altough I think, an UF14 works just as fine as an VF14.
New VF14 tubes often show the same effect, probably because there is some dirt at the cathode from production, which vanishes when the tube is burnt in. Probably, Neumann installed the VF14 in the underheated circuit of the U47 only after the tubes had been burnt in.
I forgot to mention: The reactivating should be done in AC. This is faster and safer. A more detailed explanation, written in German, can be found here.
I forgot to mention: The reactivating should be done in AC. This is faster and safer. A more detailed explanation, written in German, can be found here: http://us.f1.yahoofs.com/users/13dd71e6/ bc/U47/VF14+Reaktivierung.htm?bc1F.28Aw_ MiR8Gs.
