Okay gents. Adapted two-channel tube pre (schematic attached) to four channels and the tubes are way out of bias. A few key points:
1. The 6072 grids are at -5.2vdc
2. The voltage at 6072 pin 6 (1st gain stage) is about 13.5 vdc higher than it should be.
3. The 6072 pin 1 plate (2ns gain stage) is about 5.5vdc higher than it should be.
Would it be preferable to increase the plate resistance to lower the voltage or adjust the cathode resistors?
