Is the original cable in such a bad state that it has to be replaced ? Why not just shorten it a bit ? This Belden made is much better quality than the ones you bought . Having made both (vintage cables redone or new Gotham/sommercable) the mecanical construction of both GAC7 and Sommercable is poor compared to the belden and i am quite confident that it has as least same if not better electrical properties aswell. Even redone in 2024 the Belden made will last longer. If not convinced you can make a simple test : take a little portion of 10cm between your fingers and try to twist the cable longitudinaly . You will noticed that the Belden is nearly impossible to twist where both Gotham and Sommercable (the worst) have poor mecanical resistance, year after year it will end to a bad shilding. The amount and arrangement of wire in the shield is also much superior in the Belden. At least do not trash it , clean it and conserve it for the future. And also note that changing the cable will lead to recalibration of the PSU.
